1 members (Scott35), 270 guests, and 29 robots.
#64152 04/01/06 02:12 AM
Sixer Offline OP
Why do they make fuse rejectors for 30 amp plug fuses, when a 30 amp plug fuse is the biggest they make? I thought the rejectors were so you couldn't increase the size of the fuse, but maybe I'm missing something here?
Sixer
#64153 04/01/06 03:48 AM
e57 Offline
They reject different fuse types as well.
#64154 04/01/06 05:47 AM
Define the term "rejector"?.
#64155 04/01/06 06:46 AM
Mike you can find info here
http://www.littelfuse.com/cgi-bin/r.cgi/en/prod_series.html?SeriesID=129&LFSESSION=pkqP0Dgxlf
Older fuse holders in American homes could accept a fuse from 15 to 30 amps.
Many times the homeowners would replace the 15 and 20s with 30s.
So now we screw in a permanent adapter that allows only the correct size fuse replacement.
#64156 04/01/06 11:12 AM
I was wondering what you meant when you said a " 30 amp rejector"!
I have never really seen those " Type S" fuses around here... The only one I think I have actually seen was at my old work in the fuse isle buried under a mound of dust!
The " Rejectors" I know of were plastic rings of either the 15 or 20 amp version that you screwed into your panel with a special fiber tool...The 15's would only allow a 15A fuse in but the 20A rejectors would allow a 15 or 20A fuse to be inserted... They worked but I sometimes had problems with them when using some brands of type "D" fuse of the correct rating, the rejectors rejected them too!
#64157 04/01/06 03:21 PM
Sixer Offline OP
Rewire, I know of the rejectors you are talking about, but those are different. I haven't seen those in years.
The ones I'm talking about take the type S fuses that Iwire has linked to. This is the only picture I could find of the adaptor: http://www.hvactool.com/product_images/MA-16SA.gif
The little wire sticking out the side of the threads make it tamper resistant.
My reason for this post is lately we've been installing a lot of these rejectors (adaptors) and type S fuses to satisfy the insurance companies requirements. I couldn't figure out why they even made one for 30 amps, but e57 answered my question (duh...I never even thought of that!)....thanks.
Sixer
#64158 04/01/06 05:36 PM
They used to make a 35 amp edison base fuse.
#64159 04/01/06 11:41 PM
The S adapter also rejects pennies, gum wrappers and aluminum foil ... even the 30.
The 30a adapter will take a 20 (same thread size) but the 20 won't take a 30. There is a shoulder on the 30a fuse that keeps it from fitting in a 20a adapter.
Sixer #218334 03/19/17 02:45 PM
SMM Offline
Anybody can help to let me know from where I can buy fuse rejectors, I asked different supplier, nobody carry it
Sixer #218336 03/20/17 08:14 PM
Go to Bussmann.com or Littlefuse website, customer service, and ask for a supplier in your area.
