0 members (), 164 guests, and 12 robots.
#61424 01/26/06 09:58 AM
They're all over the place here, and they are for larger birds (Hawks, Crows, Falcons, Eagles...) In a 5 mile lineset I drive most every day they went from triangular to horizontal with these bird things; back and forth a number of times... Where there's a three phase airswitch bar (if that is even the right name...) I can understand, but is there an advantage to two of these per pole vs. the triangular pattern?
Mike Wescoatt
#61425 01/26/06 06:55 PM
WFO Offline
My Boss is from West Texas and calls them "Rapture" protection.
I tried to explain the basic differences between the "Rapture" and raptors.
So far, no luck [Linked Image]
#61426 01/26/06 07:08 PM
I am now guessing they are there to keep the elephants off the poles.....and apparently they are working just fine....
Dnk...
#61427 01/26/06 09:14 PM
WFO Offline
Quote:
"I am now guessing they are there to keep the elephants off the poles.....and apparently they are working just fine...."
LMAO!! [Linked Image]
#61428 01/26/06 11:58 PM
It could be "rapture". There is a blinding flash of light and a soul is on it's way to heaven.
#61429 02/08/06 11:34 AM
Here is a link to an article in the Dec. 05 issue of Transmission and Distribution zine. http://tdworld.com/mag/power_birds_power_lines/
They are both perches and guards. As a perch it keeps the bird further away from the energized equipment, and as a guard, at least in the pic above, on the lower arm, it seems to discourage a bird from landing on the lower arm.
[Linked Image from i40.photobucket.com]
From the zine article mentioned above
[This message has been edited by rmiell (edited 02-08-2006).]
#61430 02/08/06 01:58 PM
It's a bird warmer.
#61431 02/08/06 04:34 PM
Come on guys. Its for the high leg..........
right?
Charlie
