Everyone says that Klein has this great replacement warranty. Has anyone actually tried it?
I've read through it (
here ), and from the sound of it there are almost
no circumstances under which they will replace your tool. If the tool simply "wears out" it's not under warranty, and if you damage a screwdriver from beating on it, the warranty is void. Seems to me darn near anything that happens to a tool they can claim over-use or abuse. After I learned that, I'm thinking about buying a small cold-chisel to carry around instead of using my flat-heads.
I think the locknut tools are a waste. The size locknuts that the wrenches fit can be more easily tightened by simply turning the connector.
-John
