546
27
90 ft. of 3" PVC with 1 90 deg. sweep at the meter socket and 1 at the other end stubbed up about 3 ft. How hard would it be to pull (2) 350s and (1) 300 kcmil by hand?
My "Pulll-o-meter" calculator comes up with 0.75 Gazillion degrees of "hard."
Pipe's plenty big but the 90's will kill ya.
and I thought it was gonna be an X rated post....shame on me
Better soap 'er up good! If your 90's are pvc and not galv. rigid, you'll get some drag on the wire.
shouldn't be too hard. I've pulled 4-500s longer by hand. (there were four of us) key is to swab the conduit prior to the pull. dirt in the pipe really slows you down.
Earl
Agreed....we've pulled longer runs. Just use lots of soap. Make sure you had your wheaties that day too.
might want to think about 36" 90's and why not try a pulley and lift or truck set up some how???? i used my bucket truck to hang a pulley from and worked well
Piece of cake. Seriously.
You shouldn't have a problem but, if you are going to do this sort of thing regularly, I would recommend one of any number of different portable pullers. We do alot of bigger industrial wiring and even a small greenlee chugger is a valuable item. Good luck
Shinnston, WV USA
