516
17
What is your spin on Green wirenuts? i think using them in single-gang boxes is fine because the wirenut only allows 1 equipment ground out of the top to attach to 1 device. Now in a 2,3,4, or even 5 gang, Using a green wirenut seems rediculous if all devices must be grounded. What happened to those copper crimp sleeves, that made finishing a house so nice?!!!
The green work fine, leave the one coming out the top long enough to hit each device.
I personally only use the green wirenuts, I hate the crimp rings. Just pigtail out the bottom how ever many grounds you need but stay within the capacity of the wirenut. Ron
Posts: 9,931 Likes: 34
In my home I have avoided anything more than 2 gang in most places, just to avoid that "need a map to turn on the light" problem. In the one big box I ended up with I used one of the #10 tapped holes for a 6 hole ground bus kit. Then I used #12 stranded pigtails with terminals for all the devices. It made a very easy install. This was piped in so all the conductors were stranded with terminals. (lots of colors too)
I do waht I-wire does: leave that one conductor from the wirenut long enough to daisy-chain the grounding screws.
Greenies work great, but I see more people screw them up than I do who install them correctly.
With 2 #14s, just twisting the greenie on does almost nothing as far as twisting your wires together and leaves a really poor splice.
And for the love of god, leave enough wire so that if the splice has to be remade, you don't need to jam a pair of needle-nose into the box just to hold your conductors together.
-John
I think Greenies are nice, but a waste of money, and one more part to keep separated in the parts bag. I use tan wirenuts for 99% of my splices, the reds, grays or blues only when necessary, yellows very seldom. (And, of course, the oranges for fixtures.)
Earl
I'm a crimper. Greenies are OK for one gang boxes, but I prefer to use small crimps and leave out as many tails as the gang of the box.
I use to daisy chain a long ground but have grown to dislike that method and have been crimping for years.
Speedy Petey
I hate the damn things. There, that was easy
I never used them, becasue as a commercial installer my EGC's were insulated, and I don't like the idea of having bare conductors longer than needed. If I were doin residential, however, I would have used them.
Ryan Jackson, Salt Lake City
