1 members (Scott35), 540 guests, and 23 robots.
Page 5 of 5 1 2 3 4 5
#58644 11/21/05 07:19 AM
An amazing number of our parts, methods, and tools came from the trade- and not some pencil-neck geek sitting at a drafting table!
Yes no doubt but many times it is a fine line between an innovative way to do things and dangerous.
FWIW I like your pulling rig. [Linked Image] but I still advise against truck pulls if at all possible. To hard to be reliable controlled at the slow speeds needed.
For pulling out of hand holes and site poles I will cantilever a piece of rigid off my ladder racks with ratchet straps so it overhangs the rear of the truck. Hang a pulley from that then we can use a few guys hand pulling sideways instead of up from the ground. [Linked Image]
Bob
#58645 11/21/05 07:48 AM
I once had the opportunity to pull wire with an elephant. [Linked Image]
After she pulled some badly stuck 750 kcmil out for us, it was hard to go back to the "regular" methods of pulling.
I don't suggest using the truck, and agree with iwire that a winch mounted on a truck is a much better way to go.
#58646 11/21/05 08:39 PM
e57 Offline
There's a joint here that rents any type of pulling equipment (and benders) you want for about $35 a day. Kind of specialize in electrical equipment... Either way, <$50 for an afternoon, or even $100.... Not having a wrongful death suit, and/or 'Comp case, it's a bargian! If you need it a few times a year, buy one.
Price the rental, and or its use right into the job.
[This message has been edited by e57 (edited 11-21-2005).]
#58647 11/21/05 09:14 PM
LK Offline
"Yes no doubt but many times it is a fine line between an innovative way to do things and dangerous."
I have seen my share of accidents with home brew equipment, most of them involved serious injuries, the tested and true equipment has enough hazzards.
I prefer to rent the proper tools, part of the cost of doing business, just add the cost to the estimate.
Be Safe
#58648 11/21/05 09:19 PM
I cannot agree with you guys more. I wish I had access to rental equipment, like pullers and benders. Yet, that is not an option in my area. I have not been able to find such equipment available for rent.
As they say, necessity is the mother of invention.
