438
28
Holy,moly this is turning into a circus. Nothing is easy is it? The track heads are 120v, 50w, r-20's.
Hank
Well you wanted answers, and suggestions.... You got 'em!
I got answers all right, but I'm stiil not sure what to do. I'm not complaining, I think this is a good thing. It never hurts to get other electricians imput, especially if they have already done something that you are looking for answers for.
Hank
I just reviewed some of the posts, one said something about multi-wire circuits, well I think thats how I wired it. The outlets are on a couple of 20-amp, 3-wire circuits and the lighting is on a couple of 15-amp, two wire circuits.
Hank
Good news! The homeowner is calling in a "studio engineer" later this week. The GC and I will walk thru it with him. I will ask as many questions as I can and take as many notes. I will keep you posted.
Hank
"Feedback-Hum... Hmmm... Sound studio.... 3-wire circuits, and/or 2-wire circuits of seperate phases will do this too, if equipent is connected/re-connected on the audio side."
If that is the case, it may be as simple as moving some equipment around to be feed from the same phase. Otherwise, if amperage is low enough, make your 3-wire into 2-wire on the same circuit. That difference in voltage can manifest itself in various different ways when the equipment is fed from different voltages. Assume each piece has its own power supply, and drops voltage to whatever, and then reconnected to create another smaller voltage. Regulated or not... That differance in those two or more smaller voltages, could be what your hum is.
I can tell everyone here for sure that I definitely learned something from this thread about humming noises and the relationship it has to grouding. The most valueable lesson is to use Hospital grade MC whenever working a circuit for sound equipment. The neutral wire in a multiwire branch circuit works that much harder because of frequency difference in the equipment and that's being served (harmonics).
This site is really the best. Thank you all.
Oh, and good luck to the guy who has to fix the problem.
[This message has been edited by ShockMe77 (edited 11-16-2005).]
Me either, I will take advice about the hospital grade MC cable and I will wait to see what this engineer has to say.
Hank
CDS
Nicholson Ga
