1 members (Scott35), 534 guests, and 26 robots.
#58294 11/05/05 02:03 AM
NJI Offline OP
can anyone explain the hazards of running a 4wire subfeed 120/240 AND puting in ground rods. Other than the fact that you shouldn't i'd like to brush up on the theory behind it.
I have worked as an apprentice and on to a journeyman in a general construction company. 90% of what I do is residential. I have an associats degree in electrical technology. I have started my own buisness this year and am with out the help of other electricians. this is why i find this site so helpful.
#58295 11/05/05 09:09 AM
NJI,
Who told you that you shouldn't do both? If the sub panel is at a second building and you pull an EGC, the code requires a grounding electrode system at the second building.
Don
#58296 11/05/05 11:45 PM
NJI Offline OP
As I have understude my AHJ one or the other. Can you give me my code references? I thought one or the other. four wire or three and a rod.
#58297 11/05/05 11:47 PM
No, it's bond neutral to ground, or 4-wire.
Larry Fine
Fine Electric Co.
fineelectricco.com
#58298 11/05/05 11:53 PM
NJI, read 250.32
Roger
#58299 11/06/05 12:14 AM
NJI Offline OP
thanks, i'v been searchhing past posts and am reading as we speak..workin on it
