516
17
What's the difference between electrical drafter,electrical engineer and electrician?
About $50K a year Actually, EE designs, drafter draws, electrician installs and repairs.
LOL I was thinking a lot of things, none of which where appropriate for a nice clean forum such as this.
I was thinking the first draws pretty pictures, the second doodles, and the third makes it work.
The engineer thinks he has it right, the drafter, fixes most of the engineers mistakes, and the electrician fixes the engineers and drafters mistakes.
We all come together to make a well oiled efficient machine. (Practicing my politician skills)
Roger
Roger,
Yes, that is what the result should be, when there is good communications, on the project.
Guess who makes the light turn on at the end of the day. Edward
Thanks Edward
A draftsman knows what symbol is used for a GFI.
An electrician knows how to install a GFI.
An engineer knows that an op-amp is used in a voltage amplifier arrangement to remove clamping current from the miniature contactor when the toroid sensing coil detects a net magnetic field due to unbalanced current flow to make a GFI work. But proably couldn't pick out a picture of one in a lineup.
If all three of them were to do service changes, the one alive at the end of the day would be the electrician.
