0 members (), 433 guests, and 18 robots.
#50285 03/28/05 08:23 PM
BobH Offline OP
Just wondering how you guys that are one man shows set your residential generators considering most are over 600 pounds. Do you have the dealer deliver and set them or rent equipment to do so?
#50286 03/28/05 09:07 PM
Bob
I've always rolled them on conduit to the pad. Haven't had a problem yet, and I set a 25kW on a hill (slight) this way using the truck as an anchor.
Good luck with your install.
Rob
#50287 03/28/05 09:36 PM
BobH Offline OP
Thanks for the quick response. I was thinking that would be the way to go.
#50288 03/29/05 07:39 PM
Deleveries are only curbside. I always get crane company to set the generator in.
Edward
Thanks
Edward
#50289 03/29/05 10:19 PM
BobH Offline OP
Edward,
I was mainly referring to residential retrofits jobs, a crane seems a little overkill for a small generator but I'll bet it's been done.
#50290 03/29/05 11:10 PM
Have only installed one of these (for a friend), and we used a rolling engine hoist he had in his garage....
#50291 03/30/05 12:05 AM
Believe it or not towing companies are used in this area for a lot of this. A flat bed tow truck can transport quite a large genset and place it wherever you can back the truck into. Not a lot of money and they are happy to do it.
-Hal
