1 members (Scott35), 196 guests, and 8 robots.
#47759 01/29/05 02:20 PM
I'd be looking for a loose connection somewhere in the lighting circuits.
I'd be looking pretty smartly too, this usually means that the current isn't getting to somewhere that it should be.
#47760 12/23/05 06:37 AM
see if you can get a datalogger from the local POCO and put it on the light cct.
These will pick up spikes very accurately and then on the print out you can check a certain pattern or time slot when it occurs.
I do powerquality as well in my job and we use OSREY 1 Ø loggers for that.
