0 members (), 402 guests, and 24 robots.
#38381 05/21/04 08:10 PM
DougW Offline OP
Just got done perusing this thread:
https://www.electrical-contractor.net/ubb/Forum5/HTML/000540.html
And I'm wondering - we've all seen ads for the "solderless" (crimp) connectors, and the "squeeze-splice" devices for 10-22AWG.
(No, I'm not talking about the "big" T&B/Burndy taps/spices/crimps, just the "little" plastic ones.)
The only place I could think of is connecting line cords inside lighting fixtures or small appliances - and that's for the "butt" connectors.
Despite a UL listing, how many of us actually use them on 110? And where?
Just curious...
DougW
#38382 05/21/04 09:08 PM
Do you mean the standard red/blue/yellow "Stakon" type terminals?
I use lots of them when wiring control panels and similar equipment using stranded MTW type wire.
I also use them (spade lugs) when attaching stranded THHN conductors to device terminals. Even if it isn't strictly required according to UL, it makes for a neater job, IMO.
The buttsplices are occasionally useful for automotive wiring, such as replacing a stereo or tying in an alarm system. The insulation-piercing tap connectors are generally pretty lousy, though.
The most important trick to using these terminals reliably is a proper crimping tool. The only tools that work consistently well are the full-cycle ratcheting type, with a crimp die that completely encloses the terminal while crimping. The standard plier-type crimpers can either damage the plastic insulation or undercrimp the terminal.
#38383 05/23/04 04:51 PM
DougW Offline OP
Wondering (in particular) about these - "Insulation Displacement Connectors", that 3M says can be used for automotive or branch wiring. Anyone you know of ever used these in wiring a house - other than for phone/data/sound?
Sorry - URL seems to be too long to fit.
(long url removed - see below for working link)
[This message has been edited by Webmaster (edited 05-23-2004).]
#38384 05/23/04 06:31 PM
Tried the link with no joy
[This message has been edited by Ever Ready (edited 05-23-2004).]
#38385 05/23/04 07:03 PM
Lemme try: >> Insulation Displacement Connectors
[This message has been edited by Bill Addiss (edited 05-23-2004).]
#38386 05/23/04 08:17 PM
I don't think they are all that great for cars and would not use it outside of it. They are great for under a dash when you don't have any room or slack on the wires. Just get your pliers up there and pinch it on. They are used for a lot of auto accesories for this reason. Not a good enough connection for anything that matters on a car.
I have herd some swear by them for large ballest change out jobs.
#38387 05/24/04 05:32 AM
Thanks for the link Bill, I have used a lot of these in the past but only on low voltage equipment, I wouldn't like to use them on mains voltage.
#38388 05/24/04 03:54 PM
DougW Offline OP
Thanks Bill!
I've used them in cars myself, but was surprised to see the "UL Listed" for "house current" use, and suggested for branch circuit wiring.
I don't know if many of the AHJ's I've worked in would be too happy seeing those tucked into a 1900 in lieu of the traditional wire nut/pigtail combo!
Thanks to all,
Doug
