1 members (Scott35), 178 guests, and 10 robots.
Page 5 of 5 1 2 3 4 5
#38139 06/17/04 11:04 PM
Wa2ise.... You're still right on the pointless - point! The ground wire is (or should be) bonded to the metal box.... In fact, I'd be willing to bet the box is bonded via conduit & the green wire only attached to the box! [Linked Image] Oh the humanity! [Linked Image]
-Randy
#38140 06/18/04 12:56 AM
Of course, these audio-grade outlets cannot be mounted in just any old handy box; they require the special audio-grade beryllium-copper-dipped PVC handy boxes at $649.95 each!!!!!
Prob'ly the same folks who sell oceanfront property in Arizona. What people will believe...
No wire bias here- I'm standing on neutral ground.
#38141 06/18/04 06:24 AM
And don't forget that it will never sound right unless you install it with a special audio-grade screwdriver at $129.95.
Better use the $249.95 audio-grade wire-strippers on the cable as well, otherwise you might contaminate the electrons in the copper. [Linked Image]
