mj Offline OP
have any of you guys taken the new certification exam by iaei/nfpa ? Did you get your score results shortly after the testing ?
mj Offline OP
ELECTRICAL INSPECTOR EXAM
Got my results as soon as I finished the test.
They only give you a "pass" or "fail" not a percentage score.
mj Offline OP
master 66, I an refering to the new test,with iaei/napa, it just started this year.I took the test last week, and I did not get a pass/fail result. the print out stated it will be up to twelve weeks before my score/ or pass/fail result is known. this is misleading information, the nfpa/iaei handbook stated that the pass/fail results will be given as soon as the exam is compleated.
MJ
I thought that test was two parts, one part the test, the other part requires inspections to be made. Maybe I am wrong, I will have to look again.
Pierre
Pierre Belarge
JG Offline
I am also interested in this. I took the inspector test and recieved a 90. Our state say's I must have the certificate to get the job, but you can not take the test until you have the job, unless approval is given by the beaurea cheif. How do I go about keeping the results until an active position opens? Can I join the ICBO at this point?
This is a question I had, as well.
Your certification isn't complete without the "practicum". That pretty much leaves an associate member unable to take the test, doesn't it?
I think that all I had to do was send in a list of qualifications to experior or IAEI, can't remember, then they sent an authorization letter. I had never inspected before I took the test.
When I got the test results, I sent a copy to the IAEI and BOCA. Both sent me certificates.
Then I contacted an independent inspection agency, which is what we use around here, who the sent my qualifications to the power company (Allegheny Power) who then recognized me as an inspector.
I now work part time for the agency, how ever much I want to, and the inspection fees are split 60/40.
