414
28
Posts: 2,723 Likes: 1
Broom Pusher and Member
I prefer the #2 type, shown in Bob's picture (iwire's picture). It looks like the ones with the "forked bracket" that sets on the MC Cable's sheathing, and is adjusted / set via the 8/32 screw.
Scott35
I always used speed locks unless I was doing a cut-in box, in which case I used the one that looks like a romex connector. Ryan_J, Why don't you use speed locks or snap in connectors when doing a cut-in box?
Personally, I use the Arlington "Speedlocks" & have never had a problem with them.... I've used the Arlington version of the #2 connector with the set screw & never had a problem with those either... The speedlocks are awesome when you need to fish MC down a wall to an existing J-box.. No locknut to fuss with.. -Randy PS... I get a good reliable ground connection by bonding the ground wire where appropriate, this typically bonds the outer sheath at both ends via the connector & box.
The speedlocks are awesome when you need to fish MC down a wall to an existing J-box.. No locknut to fuss with.. Yea but how do you snap in the connector without getting a hold of the MC cable?
Ryan_J, Why don't you use speed locks or snap in connectors when doing a cut-in box? I always attached the clamp on the cable, then put it down the wall, then threaded the locknut on after the the cable was in the box and the box was in the wall. Speed locks just seemed like a PITA for this application. Do you use them for cut-in boxes?
Ryan Jackson, Salt Lake City
Straightedge... A quick, little tug on the wires entering the KO once its down into the box secures the snap in connector Otherwise, trying to get a locknut tight on a connector, when you can't grab the other end of it is kind of a pain in the #$$.. -Randy
I always attached the clamp on the cable, then put it down the wall, then threaded the locknut on after the the cable was in the box and the box was in the wall. Speed locks just seemed like a PITA for this application. Do you use them for cut-in boxes? I'm with you on that one Ryan_J. I specifically carry both types of MC Connectors on my van. I am loyal to the Snap-In Connector except for cut-in-boxes. I have to go with the thread and lock ring for my cut in boxes. I don't know how Lostazhell can snap in the Connector without pulling the conductors out of the cable. Maybe he can expand a little more?
I use the snap ins all the time on cutins. Just grap ahold of the wires and pull with a slight rocking motion and click click its in.
Straightedge, Big B explained it perfectly I'll fish the MC down the wall with either my fiberglass "pullstick" or something else... I pull the wires through the KO opening, A little tug on the wires back & forth & everythings in place.. Unless youre pulling a piece of MC less than a foot long, good chance the wires are not going to pull out of the MC sheathing. (At least it's never happened in the 100 or so times I've done this) -Randy [This message has been edited by Lostazhell (edited 05-14-2004).]
Well, when I do a cut-in-box the walls are usually only 10' high. Only a 15' peice of mc cable is necessary. I can never get the snap-tite connector to fully engage into the knock out without pulling a significant length of conductors out of the matal sheathing.
I use lock ring type of mc connectors for this application.
Tev
