0 members (), 166 guests, and 11 robots.
..this is gonna sound dopey,but I already gave my serious reply to this topic,..so,...did you know that if you take a small fluorescent tube,..small enough to fit in a microwave,and close the door,and turn on the microwave,..the lamp will glow...cool huh??? [Linked Image]
[This message has been edited by Attic Rat (edited 01-05-2004).]
i've also heard if a flourescent lamp is held outside of a microwave oven and it lights up your microwave is leaking and should be thrown out.
@attic rat:
ATTENTION!!!!
the lamp can easily blow in this test!!!!
I dont know if anyone of you wants food out of a mercury contaminated microwave...
To Attic Rat: If I am not mistaken, the ends of the lamps are usually metal. Placing a metal object in most microwave ovens is a good way to kill the oven dead.
SvenNYC Offline OP
Thanks Mac. I was about to raise that point. I've also seen websites of people who put CDs into microwave ovens and burn the metal coating off them -- makes for spectacular fireworks.
But the usual disclaimer here goes: don't try this at home. [Linked Image]
Relax guys, rizer says to hold the tube OUTSIDE the microwave oven to see if the door seals leak. True. Fluorescent tubes will glow in the presence of a strong electromagnetic field.
But if the door seals leak badly enough to allow a fluorescent tube to light, chances are you are already sterile and growing extra limbs... [Linked Image]
