1 members (Scott35), 518 guests, and 38 robots.
#31021 11/06/03 11:38 AM
aldav53 Offline OP
If a 50a 240v outdoor spa has the GFI on the plug, can I run the circuit not using a GFI breaker?
#31022 11/06/03 01:07 PM
I believe if you feed a gfci device with another gfci device it will nuisance trip.
The gfci plug or disconnect should suffice which will be fed by a 50 amp dp breaker.
Edward
Thanks
Edward
#31023 11/06/03 02:03 PM
moved to NEC Area >> here
