Being that he's from south of the border, maybe the rules are different back home. He's here sucking the country dry of all the financial, health
No they're not. Let's not turn this into another "my country vs. your country" fan-dan-go.
South of the border, you steal from your boss, you get your *** kicked off the job. It's that simple.
Hell...it's probably even worse. They might even call the cops on the crook _after_ the bossman punches his lights out. (OK I may be exaggerating there a bit).
Good for you for telling on him.
However, regardless of what others here say, do not (DO NOT!) attempt any physical violence. (I'm a pretty hot-headed guy and I have to try real hard to keep myself under control when something like that happens, so I know from what I speak - since I hear it all the time. No, thank God I've never been in gaol)
Otherwise YOU, sir, will run the risk of being arrested for assault and battery and if you do it on the job, losing your job (not a good thing in this economy). Bossman don't put up with no knuckle-dustin on the job, that's f'shore.
Tell your boss what you see. End of story.
Ball's in his court as to what (if anything) he wants to do.
Period.
And as for all of you other fellow hot-heads encouraging physical altercations, consider this: Would you do it yourself and risk losing your job, getting thrown in jail, getting YOURSELF hurt instead and eventually, having the crook turn around and sue you for what you did to him?
Take it from THIS hothead. It AIN'T WORTH IT!!
[This message has been edited by SvenNYC (edited 09-10-2003).]
