If you touch each of the two little screw heads on the circuit breaker where the wires go with the test leads of a voltmeter and it says 208 or 240, you have 80 amps of 120 volt power available. That's assuming you have a neutral too. Of course.
(signed) Sorry. I forgot my name.
