1 members (Scott35), 574 guests, and 34 robots.
#26874 06/24/03 10:50 PM
Anonymous
Unregistered
Hi All,
Have to go trouble shoot a pool light Thursday. Customer said he thought it was burned out so he relamped but still doesn't work. He said GFCI is not tripped. I haven't worked on any pool lights so I wanted to get some ideas to be armed with before I go. So far I am thinking, bad lamp or bad contact in lampholder or open neutral. I am thinking deteriorated wiring in the conduit would trip GFCI, would it not? Assuming the GFCI is working. If anyone who works on pool lights has any tips I would appreciate hearing them. By the way, it sounds like a dry-niche.
Thanks, Brian
#26875 06/25/03 08:03 AM
Hello Brian
If there is a deck box(?) take a look to see if the wiring in it is good, loose ,corroded etc... Remember the deck box has to be listed.
Pierre
Pierre Belarge
#26876 06/28/03 12:05 AM
Anonymous
Unregistered
Thanks Pierre, The job got changed to Monday. I did some studying up and it looks like my fear of the unknown was unfounded. I'll let you know what it turns out to be.
Brian
#26877 06/30/03 11:19 PM
Anonymous
Unregistered
Pierre,
It was only a bad lamp! I was all prepared to ring out circuits and all. And it was a wet niche. Pretty simple stuff. Checked all the grounding/bonding before I left. Thanks for your suggestions.
Brian
#26878 07/01/03 05:20 AM
Brian
I worked for this guy one time who used to say "spread the tools". We would go on the job and spread the tools, I always thought it was funny. He is retired and still comes to the meetings.BTW- he was one of the best electricans I ever worked with. We probably would have "spread the tools" for a bulb too.
Pierre
Pierre Belarge
