0 members (), 546 guests, and 27 robots.
#25369 05/06/03 08:12 PM
Cindy Offline OP
should know this, maybe have asked this here before even, but i never use it and i'm not too sure, sooo...
i saw 16/2 speaker cable [clear zip cord with the copper wire visible thru the clear insulation], the UL sticker at the bottom of the reel on this job site says Power Limited Circuit Cable...
this cant be put in walls, right? 725.71? refers to listed labeled cable to protect against fire spread... labeled on the wire... it was run thruout this new house under construction for speakers... so what can you use for speaker cables? i have seen some zip cords with tiny writing that nobody can read. is that it?
#25370 05/06/03 08:20 PM
They make speaker wire that has a twisted pair in a jacket like romex. I've also seen it in 2 pair for volume controls. Home Depot in my area sells it, but I get it from a buddy of mine who does low volt only. I've seen it in 16, 14, and 12 awg stranded.
#25371 05/06/03 09:44 PM
Cindy Offline OP
it should be one of these: CM, CL2, or CL3, and should be visible on the cable, right? 725.71, 310.11
#25372 05/06/03 10:52 PM
I have been using 16-2 shielded. Some stuff they use factories shielding keeps noise out. 8 cents a foot.
Phil
#25373 05/07/03 12:39 AM
Zip-cord of any size is not rated for in-wall use regardless of use, correct?
[This message has been edited by SvenNYC (edited 05-07-2003).]
#25374 05/07/03 01:06 AM
Most seriously, 10/3-G NM-B cable is four #10s for stereo speakers. [Inspector may have a cow, but it's low loss and cheap! ..and not a Code violation.]
Pigtail smaller stranded stuff on the ends. Splice in 1-gang box with 1-hole plate {or drill for 5-way binding posts} as needed.
[This message has been edited by Bjarney (edited 05-07-2003).]
#25375 05/07/03 11:12 AM
This is a photo of the roll of speaker wire used in the walls...
cindy
#25376 05/07/03 11:42 AM
i find the use of that kind of speaker wire all the time in bc canada and it has been installed very recently when i ask the home owner about it they say that a new company is installing it as prewire and and after an inspector has left who can compete with this as i need apermit to install any wire for sound, satellite, data, etc i also find it recently installed in office pa systems by so called sound contractors found in the yellow pages in vancouver bc they require ft-6 ouch
#25377 05/07/03 02:27 PM
K
Cindy,
I don't know about the cable you have, but General Cable makes one the fits that description under their Carol Brand. See it here: http://www.generalcable.com/North_America/NorthAMCat.html and do a search for C1558 or C1458
Although this is a zipcord, be advised, this stuff is NOT cheap. It is General's answer to Monster Cable. It even has vanilla embeded in the jacket to make it smell better than the monster cable.
#25378 05/07/03 07:23 PM
note:
picture above replaced to show full UL sticker.
