Electricians revenge
1 members (Scott35), 36 guests, and 15 robots.
Link not working.
Try this
https://www.cpsc.gov/Recalls/2018/s...-switches-due-to-electrical-shock-hazard
Description:
This recall involves Square D brand General Duty 30 & 60A, 120/240-volt, 2-phase and 3-phase NEMA 3R safety switches. The switches are a dark gray metal box with a black handle on the side that can be moved to an “ON” or “OFF” position. The “OFF” position is designed to shut off the flow of electricity. The switches may be used in or around commercial buildings, outbuildings, apartments and homes. They measure about 10 inches by 7 inches by 4 inches. Brand name “Square D”, the ampere of the safety switch and the 120/240-volt or 240-volt marking is printed on a label on the front of the safety switch. The recalled switches were manufactured between January 1, 2014 through January 18, 2018 and have date codes 1401 through 1803. The date codes are in the YYWW format (example: 1401 = year 2014, week 1). The date code of the product can only be found on the inside of the cover and is not accessible if the product is installed and in-service. Only safety switches with the following catalog numbers printed on a separate label on the side are included in the recall:
Catalog Number
CD321NRB
D211NRB
D211NRBCP
D221NRB
D221NRBCP
D221NRBUP
D321NRB
D321NRBCP
D321NRBUP
DU221RB
DU221RBUP
DU222RB
DU222RBUP
DU321RB
DU321RBUP
DU321RBCP
DU322RB
DU322RBCP
DU322RBUP
Remedy:
Consumers should immediately inspect installed safety switches by moving the handle to the “OFF” position. If the power stays on when the handle is in the “OFF” position, contact Schneider Electric for a free replacement safety switch and free service support to install the replacement switch. If the safety switch is not installed and included in the recall, contact Schneider Electric for a free replacement safety switch. Instructions on how to inspect the switch can be found at www.schneider-electric.us/gdss-safetyalert.
