515
41
Posts: 7,382 Likes: 7
How many solar installers here???
Please note: IF you are not a registered forum member...why don't you register & join??
Admission (membership) here is free! The members share their wealth of experience, in many areas.
Register....it's quick & free, and there are only a few 'rules'.
Sounds like no one here is installing solar??
Not installing but designing and inspecting a fair share.
I have installed several systems in the 3kw range up here. Scheduled to install a 2600w system this summer
I'm connecting two new solar panels in parallel on an RV, for a grand total of 12W/800mA/15VDC... does that count as a solar install? The manufacturer says I don't even need a charge controller until I reach 15W, but I’m putting one in anyway, since I may also want to connect the existing 6W panel, if I find that it's still functional.
Kjay:
OK, IMHO you're in!!!
Designing and installing here.
50kW to 1MW systems, 18 so far and almost 10.3MW in all in the last two years.
Vindiceptor: If I haven't said it yet....Welcome to ECN forums!!
You are a solar installer for sure!! Have you checked out the PV pics floating around this site? Most are from installs in the Twp I work in as AHJ. We have a 4.xxMW system that is operating in 'test/certify' right now. That's in a thread called 'Bigger'. I'm hoping to get some pro pics released from the owner soon, ad there is supposed to be a video documentry of this project coming.
Anyone else???
I installed, for a Customer, 6 kW pv some 16 years ago 3 on south facing 3 on west facing, 2 Sunny boy inverters plus export meters. Installed 600 watt pv on my own property some 8 years ago, and due to install another 150 watt on my property, both of these feed into a battery set
Odbob:
Welcome to ECN Forums from one of the 'Jersey Guys'!!
Jump right in anytime you feel the need!
