156
8
Posts: 7,382 Likes: 7
Guys:
How do you test AFCI operation?
Test them? I'm happy if they hold.
Rewire:
OK, elaborate please.....brand?, OK for all mfg?, satisfaction? Please!!
Posts: 466 Likes: 1
John,
The only recognized test is to use the TEST button on the breaker.
How does the test button on an AFCI work, does it simulate a parallel arc fault?
I use the test button, is there an approved tester?
Thanks to all. There are testers available, although I have seen/heard of conflicting info.
Basically, AFCI is new here in NJ, and I'm on an info search.
Posts: 9,932 Likes: 34
Nobody really tells us what the test button does. For all we know it is just a shunt trip but I bet it simulates a ground fault. The manufacturer designs the proprietary circuit and they decide what a good test might be but I doubt it tests all the possible failure scenarios. They also say you can't believe a negative result from someone else's tester so draw from that what you like.
its made by Ideal model 61-165 I purchased it two years ago it works fine.
CDS
Nicholson Ga
