1 members (Scott35), 565 guests, and 35 robots.
#192839 03/05/10 10:43 PM
SJT Offline OP
Does the code allow you to run a conduit from the side of a Wall Mounted Metal Halide fixture(Wall Pack), if an existing feed runs into the back of the fixture? Would the fixture then be a raceway? I may go a different route and not pick my feed for a new light off of an existing wall mount fixture. TGIF
SJT #192841 03/05/10 11:15 PM
K
410.65 in the '08 NEC specifically allows luminaires to be connected together that way. It also states that the fixture is not required to be listed as a raceway for this purpose.
KJay #192846 03/06/10 03:32 PM
I agree with KJay. I don't believe there have been any changes from previous NEC (2005-2002, etc)
HotLine1 #192851 03/07/10 12:52 AM
This is the easy way to add a fixture to an existing building
Rewire #192853 03/07/10 01:09 AM
SJT Offline OP
Thanks for the replies. When we install the 3 new lights, we may be replacing the wall pack with a weather-proof round box. The 3 new lights may shine enough light.
