Page 4 of 4 1 2 3 4
Romex2121,
I appreciate your comments. Though I can't account for any local codes you may be working under and also kitchen circuits if installed per code could easily be overloaded if installed per code minimum standards, I do not know of any code requirement for a maximum of 4 receptacles on the kitchen counter top small appliance branch circuits. Keep up with the good practice.
Shane
Romex2121:
Where are you quoting the max of four (4) receptacles per 20 amp SA kitchen circuit?
Is is a local thing?
Originally Posted by HotLine1
Romex2121:
sorry,, i was quoting a NM code as the NEC,, per NM, we can only have (4) recepts per each (min. 2) 20amp kitch circut,, 2foot from an opening,be it end of counter tops,refer, range openings,sink edges,,etc,, and then 4foot spaceings,,all GFI protected ,,, sorry for the confusion,,,,,,,,,,,,
Page 4 of 4 1 2 3 4
