2 members (Scott35, gfretwell), 517 guests, and 30 robots.
SvenNYC Offline OP
I see these for sale in hardware stores.
Most of them are Nema 1-15 caps, though (made either by Eagle Electric or Gem Electric).
Why make the pins out of steel instead of copper or brass?
Usually the pins wind up rusting after a few years in service, particularly when it's on something that gets constantly plugged and unplugged (and the zinc or copper plating rubs off the steel blade).
I've run across a number of such rusted attachment plugs on old lamps and other appliances
Normally I avoid them and choose copper bladed caps unless I have no choice, but it always intrigued me.
Also steel isn't that good a conductor, and don't you have some sort of reaction when you connect things like zinc/steel and copper, or is that only with aluminium?
Hey Swen:
My best guess, and IMHO:
Copper prongs on plugs would be to "soft", and would be an additional cost factor in mfg. Brass was/is used, also brass plating, and nickle plating on whatever base metal the mfg uses.
Im'm not a metalurgist, but I don't think there is a problem with any of the dissimilar metals you mentioned.
Also, you stated that you have seen "rusted" attachment plugs, I can't recall ever coming across any. I'm not doubting your comment, but are the ones you found a "factory" plug, or an aftermarket plug?; and are they from the USA??
SvenNYC Offline OP
I was referring normally to replacement (aftermarket) caps.
Most factory molded plugs are made of what seems to be nickel-plated brass (it definitely isn't steel because it's not magnetic). On a side note, I have a small GE alarm clock (probably 1960s or 70s vintage) where the blades on the plug are aluminium!! [Linked Image]
The rusted prongs on cord caps I've run across are American.
Joe Tedesco once posted a picture of a stump of lamp cord with one of those round rubber replacement caps and the pins were visibly rusted.
I haven't been able to find the picture (perhaps it was deleted). Maybe Joe can repost it? [Linked Image]
Don't have a digital camera, or I would take a pic of one or two of such old ones I've removed that I still have lying around at home.
I know this really isn't about the material the plugs are made of, but does anyone know why plugs have those holes on the very ends of them?
Lee
