0 members (), 160 guests, and 8 robots.
Page 3 of 3 1 2 3
Found my local city's "When is an inspection required?" Permit Guide"
http://www.cityofchesapeake.net/services/depart/neighborhood/inspect/handouts/homeowner-guide.pdf
E for electrical permit / N for none required:
4 . HOME IMPROVEMENT (ELECTRICAL)
Replace switch/outlet plates N
Replace outlet plates N
Replace junction box covers N
Replace electrical wiring E
Relocating switches E
Relocating outlets E
Relocating lighting fixtures E
Relocating sub panels E
Relocating panel box or changing service E
Installing smoke detectors (wired in) E
Installing smoke detectors (plug in) N
Installing smoke detectors (battery operated) N
Replace outlets N
Replace light fixtures with same style fixture andequivalent
wattage N
Replace light fixtures with different style fixture and/or more wattage E
Replace circuit breakers (plug type only) N
Replace fuses N
Mike, I think you may have misunderstood.
This system is not the primary Life safety. Globally I think we are on the same page with those.
It is a fire suppression system for an IT data room.
The panel is outside the protected room (per code).
This 9'X9' room has used maybe....50' of wire. COMPLETE!
Any way, The Inspector new his job. Rightfully called it.
But, still revenue Enhancement.
Keep in mind that the permit fees cover all the expenses of the code enforcement dept. Any 'excess' goes to the twp general fund.
Again, that's the scenario in a perfect world.
There have been a few local instances of financial disasters, but that's another story.
Page 3 of 3 1 2 3
