1 members (Scott35), 136 guests, and 13 robots.
Page 3 of 3 1 2 3
Originally Posted by gfretwell
I know they can weld, grind and polish stainless to make the outside look like it was always one piece of metal but the inside could look like a hacksaw blade.
I love that response! Well stated for sure.
I completely missed the OP's intent here. I thought we were speaking of field-installed material where the NEC would likely be the most likely code being referenced. True, if it is a skid-mounted or portable assembly, just like a manufactured home, the rules change dramatically.
---Ed---
Actually this is sanitary tube that is argon purge welded. The inside of the pipe is not how you described. The seam on the inside has less than an 1/8" "smooth" seam. As I stated the welds are performed by the same crew that is welding the pipes for the rest of the aseptic or sanitary food/beverage process process.
As for the skids, unfortunately even though they are simular none of them are exactly the same so I do not think that we could have them listed.
I agree this is special welding, not what
I see.
Perhaps you could get closer to the letter of the code of you pulled a cable through the pipe? I am starting to believe I would 90-4 you with THHN if you could show me the inside of some of your welds. A guy can screw up the deburring process with EMT and I just cut my finger yesterday on a rigid coupler. At a certain point we just have to ask ourselves "is this really safe?"
Page 3 of 3 1 2 3
