0 members (), 560 guests, and 20 robots.
#179606 07/23/08 05:15 PM
Took these at an apartment complex. I think the tree was a shrub when it was built. They did use treated lumber for the temporary supports. Unfortunately they didn't use it for the back board. Not a question of if it will fail, but when.
Alan Nadon
[Linked Image from electrical-photos.com]
Did the siding fit close when it was installed? If so, then the wiring exiting the back of the enclosure is the support.
Larry C
Z
Oh boy! And I bet the owner is looking for a quick and cheap fix involving plumbers tape and some deck screws.
The 'quick & cheap fix'? This situation would result in a violation notice, an unsafe structure posting, and a call to the utility for an immediate disconnect at the source of power. That results in a 'quick fix', albeit not cheap, but more economical then a possible fire or injury, or worse.
