1 members (Scott35), 396 guests, and 21 robots.
Page 3 of 3 1 2 3
I had a very enjoyable experience on 1 job where I pointed out a problem with the LV conduit routing to the LV guy.
He stated flat out "This is phone wire; I don't have to follow any Codes".
The fun part came because he said this while we were both standing right in front of the AHJ, who promptly replied "Oh, yes YOU DO!"
It all got ripped out and re-done.
BTW, the VAST majority of LV installations out there look just like Yoopersup very accurately describes.
Ghost307
Y
Inspectors
I am a licensed inspector in two states and we have to go several of hours in the Code in all parts to maintain our licenses. When I inspect Low voltage (50 volts & under) or line voltage (up to 600 volts) OR high voltage over 600 volts all must comply with the State & Local Codes. I think low voltage installers should be Licensed like Electricans so they WOULD be required to get the PROPER education in there trade, and attend upgrade classes . Electrican in most states are required to take Code upgrade classes .Thus they keep up with the current codes and standards. Be QUALIFIED to do your job.
That is required here in the DC area, including Maryland and Virginia. I am 100% in favor of it. Problem is, nobody enforces it, in fact the inspectors hardly even show up for the LV inspections. They might check our fire stopping while on-site for other inspections. We just pay for the permit and they are happy.
---Ed---
I think the idea that phone wire was exempt from the code started when these guys were working for Ma Bell and had a very strict set of accepted wiring practices. Now days the telcos hire trunk slammer "contractors" and anything goes.
Most are not licensed, in spite of a law in Florida that requires LV licenses. Phones are clearly 725 class 3 and I suppose some day the AHJs will start supervising these installations ... at least until the building slowdown is over. wink
I talked to my structural inspector yesterday and he said he is really slow. If it wasn't for residential remodels they wouldn't have much going at all. Even the commercial is starting to wind down.
RE: the use of 1/2" pvc. I think it is to be avoided as much as possible. From my experience, if you use a factory 90 in the run, it can be near impossible to get a fish tape thru at times. We always used a minimum of 3/4" for anything.
Page 3 of 3 1 2 3
