hey mate,
dont bother with an alternator/inverter,
to much $$$,
get a gen set its cheaper in the long run.
cheers and good luck.
also get a certified electrical contractor to check out the installation BEFORE you connect it to an electrical supply.
Safety first, because even if it supplied from a gen set it can still kill you.
