Try switching to the proper wattage. The listing is there for a reason, and so is the thermo cut off. Fire is a bad thing!
Also, try a par-type reflector lamp. I've found that they tend to reflect the heat downward along with the light. Although this may not be scientifically correct, it seems to work.
If they still cycle, try a dimmer or CFL lamps.
Good Luck!
