0 members (), 166 guests, and 8 robots.
#167712 08/18/07 01:50 PM
I get calls from customers that dont like there bathroom fans running 24/7
I dont do new construction so I am not aware of what the norm is for these .
I know they can be interlocked with the furnace fan
or just hooked up to a lighting circuit and no switch
or a timer installed in the bathroom where the fan must run 8 hours in a 24 hour period.
would spec homes just be hooked into a live circuit and left running 24/7?
customers calls to complain and I have to tell them that we just cant have a switch installed as it isn't compliant with the building code.
Why do people repluse when i mention I need a permit to alter anywiring in a home.
then they call some handyman from the newspaper or were ever.
dougwells #167725 08/18/07 07:56 PM
Doug our code states for new homes that one fan (must be low sone) be interlocked with the furnace fan. A timer is set up by the furnace, where it will turn on both the fan and furnace fan (at low speed) twice a day for 4 hours each time. Other fans can just be hooked up to a switch. Check your local building codes.
They used to wire them using a dehumidistat but that was changed a few years ago. Never heard of a fan being connected directly with no switch. Look around for a dehumidistat - they were usually placed in a hallway outside the bathroom.
As for permits for every job, it's just a cash grab by the BC Safety Authority.....which is supposedly "NON PROFIT" (cough - bs - cough). I guess what they want is handymen doing the smaller jobs.....forcing us to take permits out for every job no matter how small is causing just that.
Sixer
Sixer #167733 08/18/07 10:27 PM
I agree - by having a TQ should give you enough credentials to do work up to a certain job cost without a permit, but if the homeowner wants to let joe fix-it do wiring then dont walk, RUN away from that customer.
By the way sixer, what jurisdiction are you in? You mention BCSA, my area, but I havent heard about the furnace interlock.
jay8 #167736 08/19/07 12:10 AM
Kootenays here. The furnace interlock is a local building code issue, not electrical code.
Sixer
