1 members (Scott35), 406 guests, and 19 robots.
What about derating???
Dave
Dave
If the conduit is under 24", it doesn't need to be derated, right?
Dave
If the section of pipe is less than 24" no derating needed.
If the pipe is longer then 24" the derating must be done but will not change anything until you get past 9 current carrying conductors with 15, 20 and 30 amp circuits.
I do find it interesting that if you stuff some insulation in the hole in a top plate you need to derate RX but you can stuff a stack like this with duct seal or some other inspecified material without derating.
Things that make you go "huh?".
