Electricians revenge
0 members (), 161 guests, and 10 robots.
#163533 05/09/07 10:36 PM
triple Offline OP
What is the definition of "electric discharge lighting"?
an arc tube surrounded by a glass envelope....??
what did I win?
F
togol you are close there.
the electric discarge lighting it pretty wide area to cover but most common used is the neon lighting , flourscent lightbulb, HID aka HPS, MH , MV, LPS and arc lights
and most electric discharge lighting is useally regulated by ballast both electronic and mangatinic but some just used plain restitors on DC system
Merci , Marc
And with arc lights, as frenchelectrician mentioned, you may include a very common one, the xenon short-arc lamp as used in cinema projectors world-wide. smile
Some examples HERE
Stupid should be painful.
In addition to Tom, Marc and Tony's replies, how about these descriptions:
Discharge Lighting...
Lighting from Lamps which do not use Resistance Elements (AKA Fillaments) to DIRECTLY produce Light output, via emissions from the filament only - as with Incandescent Lamps
(Incandescents are mostly a heat / Infrared Light Generator, with White Light being a "Byproduct").
Or:
Lighting produced via a Plasma contained within an arc tube, with Light output produced from Photons emitted from inert materials in the arc tube, due to a controlled level of current knocking the Photons loose from the inert materials, while the current flows from one Cathode, through the arc tube, and collects in the other Cathode.
Or:
Lighting from Lamps having "Negative Resistance" Characteristics, as opposed to Lamps with a "Linear Resistance" Characteristic - as would be found in Resistance (Filimant) type Lamps - AKA Incandescent Lamps.
Or: (last one)
Lamps which require the Current to be "Ballasted" (automatically regulated) by an external or separate device, in order to operate correctly (and not self destruct instantly); as opposed to Filament Lamps, which do not normally require the Current to be "Ballasted" - due to the Linear Resistance of the Filament.
I have more, but these are boring enough! wink
Scott
I like this one...
." Lighting produced via a Plasma contained within an arc tube, with Light output produced from Photons emitted from inert materials in the arc tube, due to a controlled level of current knocking the Photons loose from the inert materials, while the current flows from one Cathode, through the arc tube, and collects in the other Cathode."
as it contains the most authentic electrical gibberish LOL
ah nuts
so I left out a few minor details
whats the big deal..:))
