0 members (), 160 guests, and 8 robots.
This is not an island. It is furniture. Funiture has different code requirements (UL) than houses (NEC).
Put in a 20amp wall recept.
Wire the funiture with a plug and cord.
Thanks for all the ideas guys. I think I am going with George on this. Gfi in the wall cord to "island" receptacles.
K
Electrician02125's suggestion to wire from below is a very good one if you can fix this island securely to the floor. Perhaps with detachable kickers, the owner could unscrew some mounting brackets when it's time to move the island (when they get a dishwasher). They may want a freely movable island, but the reality is that people rarely move furniture.
Kobuchi:
...people rarely move furniture.
You don't know my wife!
-Virgil
5 Star Inspections
Member IAEI
...66wv,
Ever read "El joy de rearrangele furnitere"?
That, along with 2 pints of baby oil, and a roll of plastic wrap will either break your wife of moving furniture, break you, or cause you to want to move a little furniture every night. You know you've mastered the art of furniture moving when you wake up the next morning, and your king size bed is on the opposite side of the room from the night before. The author you may ask? Watte doctere de Amoure..... [Linked Image]
Scott,
Without trying to site a bunch of Code articles, let me throw my 2 cents in. A few years back we did a ton of work for several department stores. All of the display cases were wired from underneath with (as sparky suggested) SO cord, floor receptacles, and twist lock cord caps. If I remember correctly those type of display cases are addressed specifically in the code (the article escapes me at present, George may be on to it).
Now, I wouldn't install a floor plug in a kitchen due to the possibility spilling water into it. If there is enough clearance between the bottom of the island and the floor you could install a "tombstone" type floor plug, and not run the risk of spilled water. Or install a receptacle down low on the wall, cord & plug connect with SO. I think that there is enough "room" in the code to install it so that they get what they want, and you are in compliance with the code. If I find the article later, I will post.
Amoure,
Doc
The Watt Doctor
Altura Cogen
Channelview, TX
Oh dear lord!
LOL!
I'm embarrassed!
-Virgil
5 Star Inspections
Member IAEI
