#161967 04/10/07 10:21 PM
derater Offline OP
Does changing the breaker constitute " working on the circuit" ? i.e. does a panel change (only) require AFCI's for bedrooms ?
That is going to be a local call at plan review time.
derater Offline OP
Gfretwell; way past planning. the ? relates to a legal matter. IS it code or not ?
Derater:
In NJ, this may be classified as a 'repair' and not require a permit or insp.
NJ does not require AFCI protection, as it was amended in the UCC.
Probably a local/area clarification.
Where are you??
derater Offline OP
I'm in Cent Pa. A 'home inspector' is contending that changing out the panel requires installing AFCI's. I've never heard of such a thing.
What was there previously, breakers or fuses? Were any circuits added?
The 2005 code requires AFCI protection of the branch circuit supplying all 120 volt 15 and 20 amp outlets INSTALLED in bedrooms of dwellings. A simple panel replacement usually does not involve any installation of new 120 volt outlets in bedrooms of dwellings, so therefore a careful read of the code section requiring afci protection will highlight the fact that "home inspectors" are generally as far off as my spelling seems to always be.
I assume it is universal but any permit pulled in Lee County Florida will go through plan review. It may just be a rubber stamp but it can also be kicked back if it does not include the things they require. That is where the decision would be made if a panel upgrade triggers AFCI installation.
Of course if this gets done without a permit I am not sure who would be there to tell you AFCIs would be required. It is certainly not going to be a home inspector. They are not legally able to cite code unless they are licensed CODE inspectors. Florida does not even recognize "home inspector" as a regulated industry and their "inspectors" are just informal advisors with an occupational license. A home inspector can advise a client of anything they want, down to their favorite color for the toilet but it has no force of law.
BTW if you want a laugh, go over the the NACHI BB and see the ridiculous things working home inspectors think are "code".
http://www.nachi.org/forum/forumdisplay.php?f=19
Greg:
Yes, we 'review' each app, but plans are not required for 'minor' work (EC's)
"Home Inspectors" can only 'suggest', not require anything here. Most, if not all 'suggest' that a Lic Professional be consulted (CYA on that)
