Josh,
If this VHF set is only a reciever, you can pretty much use what you like on it.
However, something that is resonant at the frequency you want would be good.
I can't remember if Aeronautical signals are Vertically or Horizontally-Polarised, however, there is a 20dB loss in signal if you have the wrong polarisation.
I have an idea that it's Horizontal (ie: with the elements flat, as opposed to perpendicular to the ground).
If you are going to use any sort of dipole antenna, you'll need a balun to match the antenna to your coaxial cable, without one you'll lose signal.
Hope this helps.
