560
20
Posts: 4,116 Likes: 4
My understanding is that an areas' Building Code is what specifies the Electrical requirements, whether it is compliance with some version of the NEC or something else.
My question is, what does your Building Code actually say about Electrical work? What is the language?
Bill, I don't have my building code book handy but I beleive it states that all work is to be done in accordance with the Mass Electrical code. (Tne NEC with amendments) It also specifies some things like lighting locations, and switch locations.
Bill, Here's one from the city of Conroe,Texas. Electrical Section is Chapter 6. It starts with a short title,then the object and scope.( up to a $2000 a day fine for violations ).A couple of sections about the City Electrician.Finally gets to Art.II which covers licensing.Then Art.III covers the Installation Standards (99 NEC with local amendmentts )Art.IV covers permits and inspections http://livepublish.municode.com/22/lpext.dll?f=templates&fn=main-j.htm&vid=10593 I have also found other city codes by doing a search on the LivePublish MuniCode website. Donnie
Donnie
tx, Your link didn't show any codes. Al, I'm trying to understand how our own "newly found" NY Building Code is supposed to be understood. Let me see if I understand yours correctly. All electrical wiring, apparatus and equipment for electric light, heat and power, technology circuits or systems shall comply with the rules of the department of commerce or the department of labor and industry, as applicable, and be installed in conformity with accepted standards of construction for safety to life and property. For the purposes of this chapter, the rules and safety standards stated at the time the work is done in the then most recently published edition of the National Electrical Code as adopted by the National Fire Protection Association, Inc. and approved by the American National Standards Institute, ... This sounds to me like you automatically go to the latest NEC as soon as it's published. Is that what that means? ...provided further, that in the event a Minnesota Building Code is formulated pursuant to section 16B.61, containing approved methods of electrical construction for safety to life and property, compliance with said methods of electrical construction of said Minnesota Building Code shall also constitute compliance with this section, This means that any Electrical related info in the Building Code is also acceptable? ... and provided further, that nothing herein contained shall prohibit any political subdivision from making and enforcing more stringent requirements than set forth herein and such requirements shall be complied with by all licensed electricians working within the jurisdiction of such political subdivisions. Basically, Municipalities can adopt their own rules, but not be more permissive? And it only has to be followed by Licensed Electricians?? Whoa! Is that a loophole or what? Bill
Sorry Bill, When you click on the link, there is a table of contents on the left side. Click the + sign next to Chapter 6 Electrical Code*. This will give you a drop down menu of 4 different articles. Each Article also has a drop down menu that can be accessed by clicking on the + sign next to it. Or, at the top of the page, there is a bar that contains next, or previous document that can be used to scroll through the different ordinances.
[This message has been edited by txsparky (edited 04-25-2003).]
Donnie
Ah, I didn't wait long enough for it to show up maybe. I see it now. I'll look at it a bit later, Thanks.
Bill, Ain't language a be-a-you-tea-full thang? This sounds to me like you automatically go to the latest NEC as soon as it's published. Is that what that means? In practice, the state legislature enacts the newly published code approximately ¾ year after publication. The section I linked to is the tip of the iceberg. This means that any Electrical related info in the Building Code is also acceptable? Yup. The State gets to modify, add to, or delete. Basically, Municipalities can adopt their own rules, but not be more permissive? Yup. And it only has to be followed by Licensed Electricians?? That gets expanded elsewhere. Al
Al Hildenbrand
Al,
It sounds like you could follow either the NEC or the Building Code?
Bill is it true that New York State did not adopt the 2002 code as of yet. I was told this from an inspector from the New York board. He said they just adopted the 99 code not that long ago.
