1 members (Scott35), 169 guests, and 26 robots.
#153169 05/14/06 09:44 PM
Mike, I wondered the same thing. I may even be a 4-way. It's hard to see all of the wiped contacts.
Larry Fine
Fine Electric Co.
fineelectricco.com
#153170 05/14/06 09:46 PM
On second thought, probably not. 3- ande 4-ways usually don't have a white button.
Larry Fine
Fine Electric Co.
fineelectricco.com
#153171 05/15/06 11:11 AM
Wow! That toggle is down=on! Weird...
#153172 05/15/06 11:36 AM
Some old stuff I had on my desk because I was too lazy to put it away...
[Linked Image from i17.photobucket.com]
The three-way receptacle is actually like a US gem tap, it can be plugged in or screwed on instead of a single face plate. The rotary switch with the hexagon knob is probably not original. I found it in a former kids bedroom, missing the cover, just two layers of wall paper. The receptacle guts belong to a receptacle matching the switch with the glass plate.
Now with a few covers off...
Note the brown paper fuses in the receptacle.
#153173 05/15/06 02:16 PM
Just amazes me how equipment manufactured in those days was built to last, with some of it still in use today, and in as good a shape as it was installed. Yet, with equipment manufactured these days, you are lucky if you get a few years out of it before it wears out or burns up...
Remember that there was junk made back then. It's just that almost all of it has long since wore out or broke, and had been replaced. Thus you rarely see antique low quality equipment today.
#153174 05/15/06 10:51 PM
Actually I think that piece on the toggle moves with it. so when the lever is pulled down, OFF appears in the hole on the plate, and ON when flipped up. or at least that's how it looks from here.
Cliff
#153175 05/16/06 04:58 AM
True, you're probably right about the toggle.
#153176 05/19/06 04:11 PM
I swear I have to pay Vienna a visit someday.
One of these days I'll post some of the small collection of British electrical bits I got from a fellow radio collector.
#153177 10/30/06 11:30 AM
I've only seen one of those push button switches in person at my uncles house he was renting back in the 80's....when did they stop making them and does anyone know why?
I think I'd like those better than the typical toggle switches avaliable today.
#153178 11/01/06 01:59 PM
Toggle switches are probably cheaper to make - not as many moving parts.
