1 members (Scott35), 414 guests, and 29 robots.
#152786 01/12/06 12:19 PM
Can anyone post a pic of the type of cartridge fuses which were used in the "Main" of these older panels?
#152787 01/12/06 12:23 PM
Pauluk:
[Linked Image from altura.speedera.net]
[This message has been edited by Hemingray (edited 01-12-2006).]
Cliff
#152788 01/13/06 05:22 PM
The only thing I can see in the pic is what appears to be a large uninsulated solid conductor on the left side. All the others look pretty small.
That's an interesting thing, indeed! I don't see anything like a neutral come in with the feeders at the top either, only a red and a black wire!
#152789 01/14/06 12:25 PM
Thanks! What would have been the typical rating of these in the era in question? 50 to 100 amps?
#152790 01/14/06 12:34 PM
for the main fuse? the main was usually 60A max, with the range block having 40A fuses.
Cliff
#152791 01/15/06 09:45 PM
Love the "Shut both breakers", when of course if you are using that terminology it should be "Open both breakers" as shut would technically leave the circuit energized.
#152792 01/16/06 12:54 AM
Y
Might want to omit any reference to "open" or "closed" where unqualified persons might be involved. "On" and "off" are less likely to be misunderstood.
#152793 01/17/06 10:32 PM
Don't you just hate those blue plastic NMC clamps
Thanks.
#152794 01/18/06 09:04 AM
Mike - After looking closely at the photo I can only guess that the solid conductor you see must be the neutral(??) I'm sure there was a neutral, I think! :-) There was actually very little load on this panel. Well under 60A. I beleive when first checked I was told 18A with the frost free frig running. Gas stove, gas hot water, oil heat, no A/C.
#152795 01/18/06 05:07 PM
Now that's efficient use of electricity! [Linked Image] I wish there were more people using so few electricity - would really help our environment.
