Electricians revenge
1 members (gfretwell), 176 guests, and 12 robots.
#148062 05/22/03 04:34 PM
CPSC, United General Supply Co. Announce Recall of Extension Cords
WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission announces the following recall in voluntary cooperation with the firm below. Consumers should stop using recalled products immediately unless otherwise instructed.
Name of product: Extension Cords
Units: 8,200
Manufacturer: United General Supply Co., of Houston, TX
Hazard: The extension cords have undersized conductors and no over- current protection which causes overheating, presenting a shock and fire hazard.
Incidents/Injuries: United General has not received any reports of incidents involving these extension cords. This recall is being conducted to prevent the possibility of injuries.
Click >> more info
I have _NEVER_ seen a regular extension cord for sale in this country (USA) that has "over current protection".
I have seen POWER STRIPS with fuses and circuit breakers.
But a regular 16-gauge zip-cord or heavy duty 14-gague double-jacketed extension?
NEVER!!
You'd think OCP for these devices would mean a fuse carrier in the plug or in the connector. There is neither (and I've cracked a lot of them open intentionally).
Unless they're putting the fusible link in the wire itself? But that would probably be illegal since if the fuse went open it would probably melt the entire cord insulation!!!! [Linked Image]
[This message has been edited by SvenNYC (edited 05-23-2003).]
Sven,
You're dead right there, about the OCP on an extension cord.
I can't say I've ever seen one either.
And going by the article, if these cords come from where they say they do, you won't find one on these cords either!.
Putting a fusible link in the flex itself would be illegal, as it would require a joint between the link and the wire.
I think the mention of over-current protection was just an attempt to better explain why undersized wires are a hazard to those that might not understand the issue.
