506
19
I would like to get opinions for a new type receptacle that has temperature sensing built into it. I have invented this and am in the process of UL Listing. It is a new catagory for receptacles. More information can be found on My web site www.FFProducts.com. I am looking to raise the bar on electrical fires, any input would be appreciated.
Posts: 7,382 Likes: 7
Hey Bob, welcome to the ECN group, and get ready for a great place to read & write, and learn.
Interesting item. What are you going to call it??? TSI (Temp sensing interupter) HHI; (Hi heat interupter) HCI (Heat circuit interupter) HDI (Hot device interupter)
Hey 66, what do you think??
GFI, AFCI, and now.....??
Then, maybe someone will incorporate the devices together...
A GFIAFCITSI ??
Some humor within a long tough day... Seriously, if it works, it could be a good thing. John
[This message has been edited by HotLine1 (edited 10-02-2002).]
Posts: 4,116 Likes: 4
Bob, Welcome, I hope that you're up to some questions. I'm sure that some will follow. BTW, I noticed your address, you didn't have far to go to get to this website, our servers must be across the street from you! Bill
greetings Bob,
It is a very interesting point-of-use concept that you have here incorporating a thermal cutout into a device.
I imagine that any T-unit would need be proximal , and only serve that which is also.
Do you have a pictoral? schematic? etc....
Greetings Bob This sounds like something that would better serve than AFCIs. To be accepted costs are going to have to be controlled. If these item add up to the current cost of GFCI receptacles, it would be a much easier sale than the expensive AFCIs. Of course reliable and easily understood technology ( missing from AFCIs)will make all of our safety efforts more acceptable to our customers. Good luck
ed
We briefly discussed this product in the long AFCI thread last December. AFCI thread Look on the second page. Not too much support for the product back then. Don
Posts: 2,236 Likes: 1
I like the idea! Monitor the temp of the hot and neutral bars, if it crosses a threshold of say, 120ÂșC, then *click*... No melting plugs!
Please pursue this idea, lots of variables and complexities to overcome, but I like it in principle!
Posts: 1,498 Likes: 1
Hi Bob!
I've had a look at your website. The product in itself is exactly what I was looking for some time ago.
What I do question is the fact that you have put the protection in the receptable with a manual reset (switching off the circuit breaker) Isn't it better to make quality receptables? (More stringent UL, CSA or CE requirements)
I would have thought it to be all those worn out and overfused old receptables that ran the risk of starting a fire. Wouldn't this product be of more use if put in the plug? The user will then have to pull the plug out of the socket, let it cool of and then (hopefully) plug it in somewhere else.
By the way: There is market you may not have thought of. In the US there is only one type of plug/socket. In Europe there are several, more or less compatible. (Which plugs are compatible with which sockets depends on the amount of force and ingenuity used)
Personally I'd love to see a version of the Europlug (a flat plug with flexing pins small enough to fit all sockets) with overheat protection.
Is it also possible to include short-circuit or overcurrent protection in your device? (I'm thinking of plugs for the British market)
[This message has been edited by C-H (edited 10-03-2002).]
Seems like a similar concept as sensing temperature at a circuit breaker, THERMAL magnetic trip. How is this recept different than a cb, other than it is point of use.
Ron
"...thermal technology..." "..There are many aspects of this broad patent..." "...the many and varied electrical products, machines, equipment and testing devices used in..."
Grossly nonspecific. No real product availability found.
