Burn Baby Burn!!!
Man, this is supposed to be fun Dude...
Look, your blood pressure is rising.
So you're telling me that when you hook 240V up to an oscilloscope that you will see two independent sine waves 180 degrees apart, or will it look just like a 120V sine wave with twice the amplitude?
It's not like one is +120 V and the other -120 V.
Precisely...that would be 180 degrees out of phase and produce 0 volts.
Got to admit you have something there with the 6 and 9 phase thing, although lag was mentioned to be more of a factor there.
Waves 180 degrees apart will cancel each other out assuming everything else is equal. Please do not attempt to change the laws of physics to support your arguments.
Thank you.
BTW, if you had been as observant as you think you are being, you would have noticed that my post explaining 120/240V systems was cut and pasted from another post. Pardon me for not editing out anything redundant.
Once again, thank you.
Oh yes, and I've learned that it is better to let people think you're dumber than you really are rather than the other way around.
Just a thought...
Oh yes, and if I had failed to mention the "natural grey" part, you seem like the type that would have jumped all over that too.
[This message has been edited by sparky66wv (edited 05-12-2001).]
