1 members (Scott35), 128 guests, and 10 robots.
Yep! Fits any outlet by using different combinations of matchsticks. Earth optional! [Linked Image]
djk Offline OP
some of the non-complient adaptors on the market are only slightly better than that [Linked Image]
Don't laugh guys,
But I see these switches still in use.
These are the original switches @ 2A rating, not the new trendy 16-20A models with polished Brass finish.
Out in the sticks, they never replace anything unless it is going to burn the house down, believe me!. [Linked Image]
you say 13amp rated socket only runs at 16amp via RCD what about a 32amp ring main
Welcome woooson,
DJK is in Ireland, where they do use 32A rings, but where radial circuits feeding BS1363 outlets are apparently more common than here in the U.K.
