533
29
Another customer is complaining to me about noisy dimmers (Lutron Ariadni)I installed . What a pain. Has anyone else had this problem? Is there a dimmer on the market that is quieter? In some insrances I've found that it is actually the filiments in bulbs making noise and not the dimmers themselves. This is fustrating.
Gidday, What type(electrically) of dimmer are you using?. Also, what type of lighting are you controlling with the dimmer?. Love to know, reckon I can sort this one out for you!.
just what is it that creates the 'noise' in the first place?
This is from http://www.passandseymour.com/knowhowfaq/showquestions.cfm?faqcategory=Dimmers%20and%20Controls , Pass & Seymour: Knowledge & Know How: FAQ Q: I installed a dimmer at a new house and the owner is complaining that the incandescent light bulbs are humming. I changed the dimmer and the bulbs are still humming. Is there a problem with the dimmer or the installation? A: Why does a light bulb hum with a dimmer controlling it, is a very common question. The noise the bulb is making is called "bulb sing" or "filament hum". The sound is created from the turning on and off of the A.C. sine wave. The rapid switching causes the tungsten filament to resonate. This is not harmful to the lamp but could be annoying depending on the location of the installation. Filament hum is typical with what is referred to as "contractor bulbs". This is an inexpensive lamp that is common to new construction. The hum can be greatly reduced by upgrading the lamp. By using an incandescent lamp with a heavier filament, the hum is practically eliminated. The family dog can still hear it, but he doesn't care.
P. S. Seems that changing the bulb used can be a real hum dimmer...
In stage lighting, the filament noise is called "lamp sing." The voltage waveform serving the lamps is not a smooth, wavy sinusoid—it is sharp and ragged, changing shape somewhat over the brightness range of the dimmer control...{except at truly zero or full-on states.} The only absolute cure are these quaint, stone-age yet most gnarley things . Warning: may require a touch-up by the local plasterer after install. [This message has been edited by Bjarney (edited 09-13-2002).]
Check out www.lutron.com for more info. They also have a good tech support hotline.
I get that complaint every once in a while, but more commonly people complain that the dimmers are burning hot. I asked Lutron how hot was too hot and they said 150 degrees F above room temp. They told me to use nylon plate screws to stop the heat transfer, it works! I don't think older dimmers got that hot, why?
Correct me if I'm wrong, but didn't the old dimmers have a massive heat sink on them. I seem to recall it being because the power transistors in it were in their infancy and produced much heat, the technology of power transistors has been advanced since then and they operate a little cooler now.
Are "Contractor Bulbs", them really cheap bulbs, you get with new light fittings, these days, we have had a real problem from these over here in NZ, mainly in cheap imported (China)linear-type tungsten- halogen outdoor fittings, we nowadays, throw the lamp out, that comes with these fittings, because their life is measured in minutes, not the 1000-2000hours that they are quoted as lasting. Just a short note, on the dimmers, however, the Triac and Diac in a light dimmer, require pretty much a perfect sine-wave to operate correctly, if there are any DC or Harmonic components in the supply, feeding them, this can upset their output, quite appreciably. When light dimmers first came out over here, they had a whopping great wire-wound rheostat as a series voltage dropper resistor, and these used to hum like crazy, especially when the lamps were dimmed down low. Thank God they are gone now, they were terribly in-efficient(with heat loss) and to a certain extent they were a fire risk if the lamps were kept dimmed for long periods.
