#13421 09/03/02 07:46 PM
this is most likely an easy ?, but i do not know the ans. the ? is "can you use plastic boxes on metal studs? also, where can i find it in the code book." hope someone can help
thanks
dan
#13422 09/03/02 07:54 PM
I believe you can, there are some plastic outlet boxes that are listed for metal studs. I believe the code section you would be looking for is 110-3 (b). Here in NJ we are still using the '99 code. But I am sure it hasn't change. This is the section that says you have to install the product as per the manufactures instruction.
#13423 09/03/02 07:59 PM
I just pulled out a Raco catalog and they have a box that is listed for both metal or wood studs. The model # is 7717 for a 1 gang and # 7834 for a 2 gang plastic box. I am sure that Carlon and others have them too.
#13424 09/03/02 08:04 PM
thanks for the help harold...
dan
[This message has been edited by daniel damon (edited 09-03-2002).]
#13425 09/03/02 08:38 PM
Yes you can. P&S makes a good variety with several different fastening options.
