Ok, here's what I could find: Israel uses plugs similar to the Autralia/NZ plugs, only with hot/neutral pin upside down (V-shape, not an inverted V). One list shows a 230/400 V supply at 50Hz.
However, this list showed the following power systems for the UK:
1ph 240/480 AC
3ph 240/415
1,3ph 220/380
1,3ph 230/400
I'm wondering about the accuracy of this list..
Pauluk, have you ever encountered a 1ph/3w system or a 220/380 3ph one in England?
I've also never heard of the use of a 127/220V system in Italy.
France lists a whole batch of systems:
220/380 2,4w
115/200 2,4w
127/220
110/220
230
115/230
125/220
Spain has also 127/220 on the list.
At leat interesting.
http://www.crmagnetics.com/frequency.htm
