1 members (Scott35), 153 guests, and 26 robots.
O
its used to interupt the supply to the hot water storage heaters at peak demand times sometimes with a Hz sensitive relay or a "pilot wire' run with the network supply and into the house.
as i know it - cheers
Thanks -- Interesting arrangement.
The closest I've seen to that is the system used in some French houses which automatically cuts-out heating loads when more power is needed on regular portable appliance outlets. It's used where service is of limited capacity.
